More wiring, this is such a tedious job, I soldered every lug join to the switches as I wanted a good connection, have all the lighting, strobe, position, fuel pump, aux switch wired now to the drop down fuse board and earth strip on my firewall. I took a day's holiday day so I could get a good start on this part of the project. I also ran 3 more wires down the back of the aircraft for my position/strobe tail light which will be an Aveo light matching my wingtip position/strobe lights. Tidied up the wiring looms and general wiring. A good productive day. I am using a 30A relay for my lights as the light draw about 12.5 amps per wingtip. Wired in works a treat
