Brief Description: Installed wires in ES-00078 Connector
Installed wire labels on wires that are current installed in the wing for the stall warning switch. Completed step 2 page 16-04 – installed WH-B218 terminal wire into ES-00078 floating 8 pin connector male per Figures 2 and 3 with terminal orientation per Figure 2 page 40-05. Completed step 3 – installed WH-216B ground wire into ES-00078 floating 8 pin connector male per Figures 2 and 3 with terminal orientation per Figure 2 page 40-05. Will not mount connector until after completion of Section 40 lighting wiring.
