Brief Description: Installed falnge bearing and brackets
Completed step 11 page 10-04. Clecoed the F-1211C L7R hinge brackets and VA-146 flange bearings to the F-1211 assembly. Completed step 12 – final drilled #30 holes common to above elements. Completed step 13 – riveted brackets and bearings with AN470AD4-6 rivets – all look and measure to be good. Completed step 14 – installed snap bushings SB375-4 into F-1211 assembly per Figure 3
