Brief Description: Baggage bulkhead and autopilot brackets
Completed step 2 page 21-17 – completed trim and prime of F-1236A – L&R inboard step attach angles. Completed step 5 page 21-19 – dimpled the 4 sets of nutplate attach holes in the F-1207B baggage bulkhead per Figure 3. Completed step 6 – dimpled K1000-08 nutplates and then riveted them to the F-1207B baggage bulkhead per Figure 3. Moved to Section 39 autopilot bracket installation. Completed steps 1 and 2 page 39-04. Clecoed and then riveted the F-1207B baggage bulkhead and F-1286A servo brackets to the F-1206G-L&R baggage ribs with LP4-3 rivets per Figure 1. Completed steps 3 and 4 – clecoed then riveted the F-1286B-L&R servo angles to the F-1286A-L&R servo brackets per Figure 2. Completed step 7 page 21-19 which is done as part of step 2 in section 39-04 above. Completed step 8 – installed snap bushings per Figure 3. Completed step 9 page 21-19 – clecoed the F-1048 facet pump bracket to the F-1276 bottom skin per Figure 3 and the final drilled #30 the mounting holes. Completed step 10 – machine countersunk #40 nutplate attach holes in F-1048F bracket then riveted the K1000-4 nutplates with rivets per Figure 3. Completed step 10 – riveted the F-1048 facet pump bracket to F-1276 bottom skin with LP4-3 rivets.
