Johns Web Site
Date:  2-6-2021
Number of Hours:  5.00
Manual Reference:  24iS/U-04-07
Brief Description:  Rollover Structure and F-01207 bulkhead
Completed steps 1-4 and 6 page 24iS/U-04
Step 1: With the Roll Bar Assembly clecoed to the forward face of the F-1231D's, clecoed the Roll Bar Support Assemblies to the Roll Bar Assembly and F-01234-L-1 & -R-1 as shown in Figure 1.
Step 2: Match-Drilled #30 the twelve holes in the sides of the Roll Bar Assembly into the F-1231D's.
Step 3: Removed, deburred, primed, and loosely reattached the F-1231D's to the F-01205B-L-1 & -R-1.
Step 4: Clecoed the Roll Bar Assembly to the F-1231D's per the call-outs in Figure 1. Riveting on hold awaiting for LP4-4 rivets to arrive.
Step 6: Tightened the bolts securing the F-1231D's and torque stripped them
Completed step 4 - page 24iS/U-05
Step 4: Riveted the ES-00301 onto the F-01207C-L-1 using the hardware called out in Figure 1.
Completed steps 1-12 page 24iS/U-06
Step 1: Clecoed the F-12110 to the aft face of the F-01207C-L-1 using the two holes shown in Figure 1.
Step 2: Match-Drilled #30 the five remaining holes in the F-12110 into the F-01207C-L-1.
Step 3: Removed the F-12110 from the F-01207C-L-1 and deburred.
Step 4: Riveted the F-12110 to the F-01207C-L-1 as directed in Figure 1.
Step 5: Dimpled the nutplate attachment holes in the F-12111A-L & -R for flush rivets on the forward side of the flange.
Step 6: Separated the F-12111C into two individual parts, then machine countersunk for the rivets called out in Figure 2.
Step 7: Riveted the two F-12111C's and then the F-12111B to the F-12111A-L & -R as
shown in Figure 2 to create the Fuel Pump Bracket Assembly.
Step 8: Riveted only the bottom nutplates to the F-12111A-L & -R as shown in Figure 2.
Step 9: Inserted the tabs at the top of the Fuel Pump Bracket Assembly into the slots in the F-12110, and secured the bottom of the Fuel Pump Bracket Assembly to the F-1207C-L-1 using #8-32 screws per Figure 3.
Step 10: Match-Drilled the four remaining nutplate screw holes in the flanges of the Fuel Pump
Bracket Assembly into the F-01207C-L-1 as indicated in Figure 3.
Step 11: Removed the Fuel Pu
