Brief Description: Installed rudder pedal assembly into fuselage
Confirmed that step 6 page 27-04 is completed. F-1276C system blocks were installed on the studs in the F-1276 bottom skin. Completed step 8 page 27-03 - Removed the lower halves of the F-1235A & B Rudder Pedal Blocks and slid the whole Rudder Pedal Assembly into position in the fuselage as shown in Figure 4. Completed step 9 - Secured the Rudder Pedal Assembly to the F-I2OIB Firewall Shelf and the three F-I257 Rudder Pedal Support Channels using the hardware called out in Figure 4.
