Johns Web Site
Date:  8-28-2015
Number of Hours:  6.00
Manual Reference:  18-06
Brief Description:  Right Flaperon Skins Installation
Completed steps 1 thru 5 page 18-06 installation of right hand flaperon skins. Clecoed the A-1202B Outbd Flaperon Skin and A-1202A-R Inbd Flaperon Skin to the A-1205 Main Ribs and A-1203 Spar. Checked that the inbd and outbd flaperon skins are bent properly as shown in Figure 2. Reworkedthe inbd and outbd flaperon skins by hand until they laid flat against the main ribs.
Fit the A-I 202B Outbd Flaperon Skin and A-1202A-R Inbd Flaperon Skin, riveted the outbd flaperon skin and inbd flaperon skin to the A-1205 Main Ribs and to each other as shown in Figure 1. Clecoed the A-1201 C-R Outbd Nose Skin to the under structure as shown in Figure 1 . Riveted the outbd nose skin to the under structure EXCEPT along its inboard edge where the A-1201B-R Mid Nose Skin overlaps as shown in Figure 1.
Clecoed the A-1201A-R Inbd Nose Skin to the under structure as shown in Figure 1. Match-Drilled #30 the holes common between the inbd nose skin and the A-1210-L & -R lnbd Nose Ribs. Inserted a cleco after each hole was drilled. Removed the #40 clecos from each inbd nose rib and final-drilled #30.
Removed the A-1201A-R Inbd Nose Skin and deburred all match-drilled holes. Clecoed the A-1201A-R lnbd Nose Skin and the A-1201 B-R Mid Nose Skin to the under structure as shown in Figure 1. Rivet the inbd and mid nose skins to the under structure using the rivets called-out in Figure 1.
