Brief Description: Preparation of Left Wing Bottom Skins
Weather was sunny but cold at the hangar. Got the temperature inside up to 51F with outside temperatures in the mid 40s. Finished labeling of the left wing lighting wires at the outboard end. WH=B203, WH=B318, WH-B212. Checked continuity of each wire from end to pins in the ES-00078 connector. Continued preparation of left wing lower skins. Deburred and prepared edges then primed W-1202-L skin. Dimpled the W-1201-L inboard wing skin in two places per Figure 1 page 17-02. Deburred and prepared edges then primed the W-1201-L inboard skin. Started removal of protective film on W-1203-L outboard lower skin.
