Johns Web Site
Date:  11-30-2013
Number of Hours:  2.50
Manual Reference:  40-05
Brief Description:  Install Left Wing Lighting Wiring
Completed step 2 page 40-05 – fabricated two WH-B212 nav power wires 153” long each. Completed step 3 – fabricated a WH-B213 pulse pwer wire and WH-B214 landing light power wire each 130” long. Completed step 4 – fabricated two WH-B203 strobe power wires each 153” long. Completed step 5 – fabricated two WH-B318 strobe sync wires each 153” long. Per step 6 crimped on ES-00079 floating connector pin to one each of the WH-B212, WH-B318, and WH-B203 wires. Completed step 7 – attached WH-B212, WH-B318, and WH-B203 connector pins to the ES-00078 floating 8 position connector per Figure 2 page 40-05. Per step 11 installed connector screws MS32206-218 to secure ES-00078 connector to left wing mount. Installed ES-00079 connector pin on right wing wires WH-B212 and WH-B203.
ES-00078 on left wing
ES-00078 terminal pins
Left wing wiring
Left wing wiring
