Completed step 1 page 16-04 – attached the ES-00081 standoffs to inboard W-1208 nose rib with hardware per Figure 1 using blue Locktite as specified. Completed step 2 – crimped on ES-00079 floating connector pin to the WH-B218 wire end. Completed step 3 – fabricated 2 – WH-B216 terminal ground wires. Put ES-00079 floating connector on one end and ES-31890 ring terminal on the other end. Put one wire aside for use on the right side wing later on.
