Made new trim tab out of carbon fiber and reinforced the leading edge with aluminum tubing cut out of a pipe to add rigidity. Phenolic rib ends fit beautifully. This new trim tab is much stronger, but lighter than factory aluminum one.
Missing a connector assembly for the pitch trim wheel wire ends. Ordered from Rans.
