Drilled through-holes for aileron connect tube pillow pads and attached to steel frame on belly. Constructed 6 sleeves/bushings out of aluminum tubing for various parts of the aileron/elevator assembly rods. It was necessary to sand connect rod and steel tube it goes through due to powder coating on both. Greased both for smooth forward/aft movement.
