Moved the wings out of the living room and down to the basement, where there's a work table and good lighting. The airlerons and flaps were already stored there. Brought in some saw horses to them them on. One wing is on work table, the other hanging from the wing cradle. Yay!
Attached 20 or so hinges to the trailing edges of the ailerons and wings. Have 6 more to go on the other wing. Burned hole in aileron, then attached clip for hinge, after making spacer out of 1/4" aluminum tubing. Made more for the other aileron and flaps. Deburred.
