Removed fuel quick drain and drained all fuel from right wing. Disconnected float switch connector in right wheel well. Disconnected fuel level probe connector in right wheel well. Disconnected strobe and nav light connectors in cockpit. Cut green and blue angle of attack tubes in cockpit. Removed inboard 2 bolts connecting aft spar. Removed safety wire and 2 main wing attach bolts. Removed right wing and transported to shop.
