Right wing leading edge sustained damage from impact of a buzzard during flight. Removed pieces of buzzard. Drilled hole behind lower leading edge for drainage. Broke away loose pieces of wing skin from wing upper surface. Hosed out with water, sponge and soap as much of the remains of buzzard as possible. Removed right aileron. Removed right flap. Removed right outboard gear door.
