Hans Marchners Web Site
Date:  8-18-2013
Number of Hours:  4.00
Manual Reference:  Ch 17
Brief Description:  Cockpit 2
Attached the instrument panel skin with plenty of clecos but no rivetting as I'm not sure how the Lexan window will be attached later on. Don't like removing rivets! Also, the wing strut plates were attached. This was tough and demanded quite a bit of force to get in place. One of the bolts was difficult to reach with the two washers and the nut and needed to be glued together (small dot of super-glue) and fixed to the wrench with tape to tighten (see image 2).
Postponed the seat installation as I believe I need the space for wiring and fuel connections.
Also, will not install the Lexan windows until much later (last thing I do). Likewise, installed the seat belt attchments but awaited to attach the seat belts until later.
Wing strut attachment
Invention for tight areas
Instrument panel skin
