- Made extension piece to RHS rear baffle to suit engine - Installed vent scat tube flange on baffle, attachmnet fixxings and installed on engine for alignment fit - Drilled rivet holes and rivetted the rear baffle assembly and reinstalled baffle.
Note: The rear baffle quarters (RHS rear baffle and rear side baffle) form a single unit, which can be removed from the airframe without having to remove any rivetted connections.
