- Modified/adjusted kit parts and installed baffles on engine, due to engine size, as follows:
* Adjusted LHS rear baffle in width to suit angled valve cylinder heads and installed on engine * Modified side baffles (small adjustments needed) and installed on engine * Installed front baffles, However did not widen baffles (refer gap visible on Image 1 * Part rivetted rear baffle and after alignment check drilled and glecoed rear baffle extension piece to baffle
Note: The rear baffle quarters (LHS rear baffle and rear side baffle) form a single unit, which can be removed from the airframe without having to remove any rivetted connections.
Front baffle installed (see gap between sides and front baffle)
