HANSRUDOLF'S WEB SITE
Date:  2-16-2016
Number of Hours:  10.00
Manual Reference:  2/2
Brief Description:  IO-360 Air Intake
Air Intake manifold for IO-360
- Added #6 bolts to standoffs to act as shear connectors
- Installed flange assembly and fibreglass cone on airframe and checked alignment with air filter assembly
- Epoxied assembly in aligned position on airframe, removed assembly and completed the joint between stainless steel flange plate and fibreglass cone. Reinforced joint and cone with additional fibreglass tape
- Sanded, puttied and further sanding until a smooth entry was achieved
- Finished assembly with an epoxy paint coating
Completed manifold showing stainless steel mounting flange
Finished intake manifold installed on airframe
Intake manifold showing transition from airfilter to fuel injection servo
