HANSRUDOLF'S WEB SITE
BearHawk
Fuselage Panels
8-15-2016
Skylight above Front Seats
Sky Light Construction Sequence
- Support strips welded to formers and painted
- Cutting and fitting of window panes (Marlon FSX, an extruded polycarbon sheet material available from 0.8mm to 13mm thick) to the support brackets
- Silastic infillof joint gaps and cover strips above joints will complete installation.
Support Strips welded to formers
Support Strip details
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
