Access and Inspection Covers for control cables and linkages
Aluminium access covers and frames were prepared and frames fixed to the fuselage sides to lugs welded to the fuselage frame structure. All weld were then corrosion protected with paint
All coverplates are fixed to the frames using nutplates
