Brief Description: Installation of Rudder and Stabiliser
Installation of Rudder and Stabiliser:
- Install temporarily rudder and LHS stabiliser. Install LHS elevator and trim tab
- Install trim tab torque tube and trim actuation components (LHS control horn)
- Set out offset alignment of trim tab control horn to provide clearance to elevator control cables (3/4 inch offset from center line of fuselage). Install washer and split pin on torque tube to maintaon offset spacing (may replace washer with bushing spacer for clearance purposes, if required)
Installed empennage components
Trim actuator linkage and torque rod with spacer washer
