HANSRUDOLF'S WEB SITE
BearHawk
Vertical Stabiliser - False Rib
False Rib fitted to vertical Stabiliser
To achieve a continuous flowline of the covering around the nose of the stabiliser, false ribs were made up of shaped plywood and then epoxied to the original bottom rib
YTrial fit of false rib to achieve proper surface contour
False ribs epoxied to rib and clamped
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
