HANSRUDOLF'S WEB SITE
BearHawk
Balancing of Control Surfaces
Balancing of Ailerons and Flaps
- The aileron and flaps were mounted on na special jig to allow free movemnt
- Calculated weight to allow for covering and painting was place on the CoG of the control surface
- Counter Weight prepared for the nose tubes of the control sutface. Molten lead was then poured into the tubes
- Complete counterweight tubes were then installed in the nose of the control surfaces and then rivetted into place
Aileron mounted in jig and lead weightfor covering/paint fixed to CoG of control surface
Counterweight tube filled with lead weighed to be sure proper countereight is achieved
Completed tube inserted into nose, checked for balanced and rivetted in place
BearHawk Home
2029
Airframe Practical C
Aux Fuel Pump
Brake System
Cabin Fitout
Cockpit Roof
Colour Top Coats
Control Cables
Control Surfaces (Ai
Electrical Wiring
Engine Control Cable
Engine Stand
Fairings and Gap Sea
Flap Control System
Fuselage Air Intake
Fuselage Cowl
Fuselage Fitout
Fuselage Floorboards
Fuselage Nosebowl
Fuselage Panels
Fuselage Rotisserie
Gear Legs
Gear Strut
Heating/Cooling Sys
Instrument Panel
IO 360 Sensor Wiring
IO-360 A1A Engine
Navigation Lights
Pneumatic Lines
Poly-Fibre Covering
Port Wing
Seat Belts
Seats
Starboard Wing
Window Framing
Windshield
Wing Painting
Wings - Fitout/Paint
