HANSRUDOLF'S WEB SITE
Date:  2-28-2016
Number of Hours:  5.00
Manual Reference:  1/5
Brief Description:  Engine Baffle Installation
Initial Vans Air Engine Baffle Kit Installation
- Modified/adjusted kit parts and installed baffles on engine, due to engine size, as follows:
* Adjusted LHS rear baffle in width to suit angled valve cylinder heads and installed on engine
* Modified side baffles (small adjustments needed) and installed on engine
* Installed front baffles, However did not widen baffles (refer gap visible on Image 1
* Part rivetted rear baffle and after alignment check drilled and glecoed rear baffle extension piece to baffle
Note: The rear baffle quarters (LHS rear baffle and rear side baffle) form a single unit, which can be removed from the airframe without having to remove any rivetted connections.
Front baffle installed (see gap between sides and front baffle)
Side baffles installed
Part rivetted rear baffle installed
