Pictures 1 and 2 show the two locations where bolts are removed to enable the ignition module to be moved. It is installed on three rubber mounts, but the bolts on only two need to be removed. The plans are confusing here. Just remove the bolts and move on to the next step!
With the ignition free, it is easy to remove the Intake Manifold and Coolant Socket bolts. As described, I covered the exposed holes with masking tape to keep my workshop rubbish out of the engine.
