Keiths Web Site
Date:  3-13-2008
Number of Hours:  0.00
Brief Description:  The Lighting Option Kit
This kit provides nav lights in the wing-tips, a landing light in the starboard wing leading edge, and an interior light. All lights are LED units for low power consumption, as the Rotax is not supplied with auxiliary power-generation. The kit can be readily retro-fitted. The electrical contacts in the wing-roots of the base kit are designed for lighting, so this option does not detract from the wing-removal facility.
I ordered the kit, after I had completed the wings, so I went down the retro-fit route without any significant difficulty. Having said that, I have not fitted the interior light which requires two wires to be fed from the roll bar area to the instrument panel area. This is a pain in a completed aircraft. If you are unsure whether to fit the kit I would strongly recommend laying these two wires while undertaking the rest of the wiring. Cost and effort would be minimal at that time. Visit the VAF web site to get details of what would be required.
