I believe I have now finished work in the aft fuselage and tailcone, so no reason not to attach the turtledeck. This was deferred from the fuselage build.
Having run out of excuses, I finally had to turn the fuselage the right way up. From now on it will be harder to get at stuff.
For a single-handed operation, I found it quite difficult to cleco the turtle deck skins and the perspex (or whatever it is). I started at the back, at the centreline and worked downward and forward. Much poking about with an awl to get holes to line up, but eventually (by 19:00) I had got everything clecoed. Tomorrows' job is to drill holes into the roll-over bar, then enlarge the holes in the perspex for screws.
