After three weeks absence, I'm back in the saddle, and having difficulty remembering where I put everything. It's also too cold to work with the garage door open, so back to working in the relative gloom, with a heater on. Mental note to keep motivation up through the winter months ;-)
First task was to rivet the lugs for the seal belt shoulder straps. As ever, these just fitted without adjustment. One side of each lug had previously been chamfered so that it doesn't distort the tailcone skins (I assume), so you need to make sure you put them on the right way around.
My workbench is too high for easy working on the top of the fuselage, so I had to rivet from a stepladder.
