Last job for today was to reinstall the Turtle Deck Skin and the Aft Window with clecoes. There should be no reason to go into the aft cockpit area again, apart from installing the fuel tank, but I am not yet brave enough to rivet and screw everything up (unfortunate expression!) for the final time. The glazing needs to be in place prior to working on the canopy, as this butts up against the Aft Window. See Picture 1. You can also see the instrument panel cover in place, another prerequisite or canopy work.
