I'll probably not bother with pictures for the right wing, as it is a mirror image of the left wing. The only obvious difference is the lack of a stall warning tab on the leading edge.
Today's work was preparing the wing skins (remove blue plastic, deburr edges and holes etc.). I did the wing tip bits, the three top skins and the middle bottom skin. Two more to go before I hit the primer again.
