Keiths Web Site
Date: 8-12-2009
Number of Hours: 3.00
Manual Reference: P 17-03 Step 5
Brief Description: Complete top skins
This includes P 17-04 Step 1 also.
As for the bottom skins, the sequence is inboard skin, outboard skin, and middle skin, as the middle one overlaps both inner and outer skins. And the leading edge skins overlap the top skins. If you just follow the steps rigorously, it works. At each stage after applying yellog gunge, and clecoing, I taped over any holes that are not be be riveted at this stage to eliminate over-enthusiastic riveting.
All this riveting (actually clecoing) was causing me more grief with my wrist, so it was a relief that a wrist support appeared in the mail today. Better yet, I tried the air tool I had purchased for clecoing. Originally I had written this off as a waste of time, but once I oiled the tool it worked much better, and once I got the hang of it, the tool actually worked pretty well.
Middle skin being worked upon
Top and bottom skins done
