Another Airfix task to separate the two Tip Attach Angles. These are a bit fragile. I wasn't really happy using a hacksaw or tin snips. If I had an aluminium cutter in my Dremel I would have used that. In the event, I plumped for the tin snips, and managed. Picture 1 shows the two parts separated. The underlying plan shows how they started life.
Picture 2 shows all of the previous bits ready for priming. The long bench has the two main spars with the rear spars sitting on top. It will be fun priming these - they are 12 feet long.
