Not much work here. There are four sets of flaperon (combined aileron and flap controls) hinge brackets. I cleaned up and clecoed each left and right part together to check for fit. Picture 1.
The two flaperon hinge assemblies each contain three parts - left and right hinges and a plate sandwiched in the middle that will contain a bearing. Some more countersinking required here, for a couple of flush rivets. Picture 2 shows the sandwich without the bearing - that goes in the hole at the top, after everything is primed.
