Picture 2 shows the Starter Relay. Note this is moundered on a backing plate, because the mounting holes do not line up with the holes in the firewall. Vans released an update to fix the problem.
Picture 3 shows the Manifold Pressure Sensor, mounted underneath the GPS aerial.
