Attached the elevator push rod, and of course, I had to try it out from the cockpit. Then, I messed around with the nav light, couldn't get it to work, and later figured out it was wired to the tail strobe switch. An easy fix with the Vertical Power unit. I placed the empenage fairing on, and checked out the fit. Reailzed I'm going to need a few things from home to get that guy on. Cleaned up the hangar a bit before heading home. Don't want to leave the place a mess, in case Mike needs to pull his plane out sometime. Things definately slow down at the hangar. It's cold and I don't know where my tools are, and I usually end up needing something at home. Oh well, I'll get there.
