Sanded and reprimed the canopy side and rear fairings. I didn't like the way they looked with the yellow primer, so I did them in grey. Also removed and re-shaped the canopy lock release handle, tapped the hole a little deeper, and re-painted. I had heard that the stock handle shape can strike the windshield fairing if it's turned the wrong way, like towards the front, and crack the fairing. So I carved out an angle on the bottom to help avoid it. Last, I crawled inside and cleaned the canopy inside and out. A little overspray got underneath but the plastic cleaner I had from my miata days cleaned it up nicely. Rolled her back inside the shop. Panel. Need that. I'm getting desperate for something to do.
