Trimmed the nose wheel fairing tire hole, and then removed the nose wheel fairing brackets and bent them to fit the fairing. Then put the fairing back on, and drilled to the brackets. Then I trimmed a little more around the gear leg to allow the gear leg fairing to be fit. Then I fit the nose gear fairing, by trimming a litle off the bottom to give it clearance when the nose wheel turns. Then I drilled and riveted on the hinge to the fairing. Then I drilled and attached the main wheel fairing outboard brackets.
