Greg's RV-9A Builder Site
Date: 6-24-2009
Number of Hours: 4.00
Brief Description: Tips, Cowl
Removed the HS tips from the HS, and cleaned them up, then preped them and riveted them on. There was one little place in the right HS tip that needed a little touch up with filler, so I did that. Then I worked on smoothing the cowl nose around the spinner where the fit wasn't perfect. I don't like working with fiberglass, but it does have its benefits, you can shape it as you need to and it's very forgiving. Most mistakes are easily fixed. After I got that cleaned up, I sanded the entire surface again, and rinsed both halves off. Then I started thinking about the wing tips. First I had to align the ailerons correctly, so I found my alignment tool that I made over a year ago probably, when finishing the wings, and discovered that I had made a mistake when making it. Oh well, no biggie. Now that I understand it's purpose and how I am supposed to use it, it was much easier to make another one. Then, I made the spacers for the aileron installation. Then, using the alignment tool, I got the alignment of the right aileron done, and the jam nuts tightened and torque sealed. Then I started looking at the tip, and how it goes on. It will take some considerable trimming, I think.
