Started attaching the engine mount. Got top two holes drilled, and bolts installed, but drill bit got dull by the third hole. Need another 3/8ths bit. Then attached the air vent things on the side, with a little epoxy and 4 pop rivets for each. Used some RTV to seal the sides where I saw some gaps. Attached various hoses and fittings to the manifold mount, which I also then mounted.
