Made the downward bend and twist in both longerons. The bend was matched up with the side skin, so that was easy. The twist, not so much. I think I'm close, but probably when I see what this gets mated with, I'll have to adjust. Started taking apart tail section, and deburring. Got as far as the tail skin deburred and dimpled, along with the aft most bulkheads. Drilled the hole for the tie down in the tail skin.
