Continued work on the left longeron, and finally got the curve correct. I compared it to the 721B when I got close to the curve on the plan. I removed the twist, bent it some more, removed the vertical bend, and finally got it to match the 721B. Drilled the longeron to the 721B. Then I started in on the right longeron, and it went much faster. Actually bent it too far on the second pass. Removed the twist and vertical bend, and drilled the 721B. Started to attempt the downward bend, comparing it to the 970 forward skin, but didn't get too far when the pool started calling my name. (and the kids).
