Removed Right flap from the table, and took out most of the cleco's for use on the left flap. Cleco'd on the bottom skin, and drilled to ribs. Flipped over the flap and put the cleco's in the predrilled holes so it would lay flat. Cleco'd the top skin on, and then the nose skins. Used racheting straps to bring the leading edge skin to the holes. Worked so much better than the "wrestle until I can get one cleco in" method. Drilled the trailing edge.
