Finished clecoing in ribs for right fuel tank. Putting in the first few clecos in on the top side of the tank while out of the jig worked best. Then, the tank could be slid down into the jig and the other clecos more easily went in. Cleco'd in tank stiffeners and match drilled. Pulled out the baffles which is the back of the tank and messed around with the z brackets which will mate the tank to the main wing spar.
