Spent about an hour making the jack screws I saw on another builders website, two for each wing, to hold the middle of each wing level. They sag from the weight and if you don't support them, the skin holes won't line up. Then I deburred the holes in the front and rear spars, and alodined the holes. Then I cleaned up the ribs in preparation for priming. It was rainy and windy, so priming was out. Also countersunk the holes for the 3 middle platenuts that apparently attach the fuel tank someday. I alodined those holes and will attach the platenuts tomorrow.
