Brief Description: Match drilling L. spars and ribs
Match drilled (reamed) the ribs and front and rear spars after figuring out I didn't need to do the ones on the sides (top and bottom) because I'll need to match drill those to the skins anyway. Spent some time straightening out the ribs because some of the holes in the little tabs at the end of some of the ribs didn't match up too well. Also drilled the 3/4 inch hole in each rib for the wing wiring conduit that I ordered from Van's. Started on deburring those holes, which will take some time.
