Greg's RV-9A Builder Site
Date: 4-4-2009
Number of Hours: 6.00
Brief Description: Baffles
Worked on the baffles, got basically all of them attached to the engine, some semi permanantly. The prop oil line required a cut out, and then rubber grommet which was a real pain to get on. Also, some of the screws for the baffles are in impossible places, namely, the one near the oil filler neck. I think I'll have to remove the neck to fasten that screw, but I don't have a wrench big enough for the neck. It'll have to go on the "at the airport" to do list. Went back later in the evening and trimmed the forward sections to fit the lower cowl. Got the left side pretty much done, but not the right, because of the prop oil line, made it a little too inconvenient to remove the forward ramp multiple times. Maybe today. Nice to make visible progress again though.
