Greg's RV-9A Builder Site
Date:  3-17-2008
Number of Hours:  6.00
Brief Description:  Misc. Brackets, etc.
Fabricated a bracket for the Advanced EFIS magnometer, and cleco'd it in. I can't finish that until the EFIS is in the panel, so I can adjust the pitch. I got the roll as close to perfectly level as possible, using the digital level. Then I fabricated a mount for the fuel pumps and filter, but I'm still working on that, and how it will all go together. Finally, I removed the blue stuff from the forward fuselage skin, dimpled the holes, primed and cleco'd it onto the fuselage. I left the left side off mostly, because I'll need access over there to mount the strobe power supply bracket, after I attach the platenuts on the bracket. Then I attached the platenuts for #6 screws in the tail for the access doors on either side. I primed other various parts, including the pitot mount, the covers mentioned above, and the cover for the fuel valve. I cut out the parts for the fuel pump/filter cover, looks like it'll work. Probably have to add a few angles for support, but we'll see. I got real close to thinking about mounting the horizontal stab. That thing is huge though, and one, I'm not sure I can get it down by myself, and two, it will take up so much room in the garage once it's on. Yes, I know I could fit it and then remove it and store it again, but where's the fun in that?
