GOTTFRIED'S WEB SITE
Date:  1-23-2021
Brief Description:  Back-up battery charge port; Base plate hook up
Mounted the bracket for the charge port connector to the battery tray.
This allows me to disconnect the charge por without cutting wirest, when the instrument port is to be removed.
Also did the final hook up of the cables from the main battery to the instrument pod electrical bus.
Charge port connector bracket installed
Base plate hook up to main battery
