GOTTFRIED'S WEB SITE
Date:  2-15-2016
Number of Hours:  3.00
Brief Description:  tail fin assembly
Used some of the scrap sheet metal from trimmimg the fins for the 4 doublers to connect upper and lower fin. Cut 4 doublers 2" long and 3/4" wide. Marked locations for the line of rivets, drilled holes and installed clecos.and drilled. Cut out section for spar and pitted bottom fin to match upper fin
4 dounbler installed
